Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Sat Nov 23, 2002 5:40 pm
Get Tein RA's, they are worth the extra money. They have a larger piston, are all aluminum (weigh less and you'll never have to worry about rust), come standard w/ pillow balls, and have a threaded shock body (so when you lower the car, shock travel is not affected).
Also, you don't need all those rods, braces, and bars to reach 1g. I would replace all worn bushings though if I were you and maybe just get some sway bars.
Next, a set of good tires will be the icing on the cake. I'd buy some Azenis or some other street tires. The victoracers reccomeded to you is plain ol stupid. They are a DOT RACE TIRE! Not a street tire. They would last you all of a couple weeks of driving. At track events, they last about 4. And rain...forget about it.:rolleyes
Lastly, if you do get a race alignment, I wouldn't get 2 degrees of rear camber. I like my rear end to be able to rotate. But that's a preferance thing. Good luck.
