I have a question on this subject.....
When I lowered my 06 M35Sport with the Tien S kit, the drop was great, however, I did NOT get the "Alignment Kit"control arms (at the same time) so I ate up a new pair of Nitto ENVO's in less than a month. I purchased the Pro-Kit (Control Arms) @ 500.00ish and was able to correct the front camber (the rear was not bad). all said and done the springs were about 350.00ish with
My new 2012 Altima Coupe 3.5 SR CVT is my 1st front wheel drive car in for ever
(so forgive my ignorance please). I am wondering if I have to get control arms too, if so the cost of spring + Alignment Kit is only about 100.000 - 300.00 (if that) diff from the coil overs once you add the Front Camber Kit (entire control arms) and rear.
With that said I have seen "Pro alignment kits" which look like just a set of bolts ranging from 30.00 - 100.00+ (Very Fair) Are they all that is required the springs install to correct the camber back to factory specs? If so we are talking about less than half the cost of coils vary doable indeed!!!
If I would have done a bit more research (here at NICO) I would have waited to install the springs or just got coils, in hind-sight I would have done coils for the overall adjustment factor.
Jeremy
