180fan »
https://forums.nicoclub.com/180fan-u3602.html
Thu Feb 24, 2005 9:35 pm
Spring compressor is a must. If you try taking off the stock spring on your struts, you'll find that the little nut holding the upper plate down will shoot off like a bullet. If you don't have something that'll take most of the energy from it (like a cardboard sheet against a wall at an angle for example with a face shield, gloves, and long sleeve shirts, should it richochet back and hit you) you'll be in for a world of hurt. Rent a spring compressor, have a few large sockets, a pipe, possibly a blow torch, and you shouldn't have too much of a problem.
Remember how the spring aligns with the perches. If they're going on stock struts, you'll probably blow them pretty soon too. You might want to invest in a set of shocks designed for lowering.
