Tein S techs Or tein h techs??
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
teamieg35
need some opinions on which springs to get....tein h or s techs???? im lookin for a fairly decent drop nothing to aggressive or stocky
....also wats the difference between the g35 h techs and the 350z h techs???
Modified by teamieg35 at 9:44 PM 8/5/2007
JeromeS13
Car: 2008 Subaru Impreza STI
The difference is a slightly different spring rate. The Z H techs will yield a slightly lower drop than the ones for the G. I have 350Z Tein H techs on my car, and the front camber is RIGHT on the edge of being out of spec. So, if you want to buy front camber arms or risk wearing your tires prematurely, get the S techs. If you want a decent drop (about 3/4"), get the H Techs for the Z.
-Jerome
AddictionG35
Car: 2003 Infiniti G35 Coupe 5AT (R.I.P. 03 SEP 07)
Are the 350Z Tein H Techs compatible with the Tein EDFC?
JeromeS13
AddictionG35 wrote:Are the 350Z Tein H Techs compatible with the Tein EDFC?
H Techs are only springs. The EDFC remotely controls the dampening adjustment of a coilover STRUT. So, IIRC the only set of coilovers that are compatible with the EDFC are the Flex and the CS. There could be more, but its only coilover systems.
-Jerome
AddictionG35
Ah... see, I guess I just naturally assumed he was talking about springs AND coilovers not just the springs alone. My bad heheh
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
