Tein s springs or tein h for my m35x?
xxxalpinexxx80
Car: m35
I know that the tein s will fit on the car. It will drop it lower, which is what I want.
The tien H looks like such a slight drop that it's not really worth it.
Thing is though, later down the road, i want to get 20" possibly 22" rims, and i'm worried that with the tech s, such big rims won't fit. Should I just get the H and some 20s or 22s down the road n be safe? Im confused
zerg711
I'm pretty certain you'll be ok with 20s but I'm not sure about 22s.
I run H techs and I like the conservative but noticeable drop and I run 20s. Given the amount of lowering provided by S techs, I am certain that you will not have any problems with 20s.
mexillis
Car: M45s
You can have coilovers or air suspension with 22"s, so basically any springs would let you fit them. The problems people run into with 22"s and rubbing is going to aggressive on the offsets or too wide on the tires.
PlatinumM35
Car: 2006 Infiniti M35
Tein H-Tech Springs
Slotted/Cross Drilled Rotors
Wagner Ceramic Brakes
22x9 Status Wheels
Rear Entertainment Aftermarket
15'' RE Audio Subwoofer
Infinity Reference Door Speakers
I'm running H Tech's with 22''s. Its a small conservative drop, no rubbing at all, or camber issues at all.
morgzp23
Car: 2006 M35x
hey guys. looking to get Tein H for my m35x. just making sure, will they will fit on the car. i've looked up the part for this model and they they all say 2wd (except 4wd). so positive......they will fit?
PlatinumM35
Tein H-Tech Springs
22x9 Status Wheels
I'm not sure about that. You'll just have to wait for some more guys with x's to chime in. I do know there are quite a few that have gone with Espelir lowerings springs that are specifically for the M35/45x. Here's a link http://www.burtmanindustries.com/zoompr ... x&opt[3895]=
mexillis
Car: M45s
All the springs work for each model of the M, wether its awd, M35 or 45.
PlatinumM35
Tein H-Tech Springs
22x9 Status Wheels
Thanks Mex. I did not want to give the wrong info.
