TEIN rod's and end's...omg thier great!!!!!!!!
Nissan dominates the drift scene - Always has, always will.
Slappy
Car: 1993 240 sx coupe
Modified by Slappy at 5:11 PM 9/13/2007
takklz
Car: 1993 BMW 318i
i'll remember that when i am old enough to drive! you know what everyone wants though... pictures and videos
takklz
Car: 1993 BMW 318i
not like your good anyways j/k lol ^_^
240SicknessX
Car: 96 240 SE
im having some issues with reciving mine in............. What did you do for a front alignment? Take some measurements and "eyeballed" it back to those measurements for your toe? or did you get an front alignment?
gepeto
Car: 1995 S14
I am not a drifter and will never drift my car, but what I'd like to know is did it improve the steering "feeling" ? (I guess you understand, don't know how to describe it)
Fenvy
Car: 2005 350Z Base 6MT
isn't the spl rods thicker than tein's? spl are 32mm I believe
raging panda
Car: s13 coupe
SPL uses z32 rods, which are thincker, im not sure if you have to use their ends or if other s chassis ends fit on z32 rods. Tein rods are basically gold s14 rods though, but i got a good deal on mine, about the same as stock s14 rods so it doesnt matter, i like them.
nismostate
Car: all sorts of motorsports
and it includes a spacer for more steering angle. i love my tein's too..
yeap
Car: A sweet 2004 red tricycle.
Slappy wrote:i went out for my first drift session tonight with my new setup.
how did it go??...freakin great!!!
them tokico's are exactly what i needed, perfect for me.
BUT, the REAL suprise were the TEIN tie rod and tie rod end's..
just when you thought you were gonna loose it, TEIN was there to save you *** with sooooooo much more steering angle.
wow, i was really suprised on what a difference they made.
i recommend rod's and end's to anybody who's serious about drifting.
Yea I love mine, you get 15% more steering angle. If you car is low then make sure to watch the splash guards above the tire and make sure it isn't rubbing. Theres a lot of wiring going through that section.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
i got stock tie rods and when i turn lock to lock my wheels they rub the frame i couldnt get more angle.
sixxdeuce
Car: 93 rx7, G35coupe 6mt
Then you need to space the wheels out farther, aka lower offset wheels or smaller tires. The tein inners are same diameter as S14 inners so outers for both S13 and S14 are the stock S14 thread size. The ends really are not that good, just a rubber ball joint like stock, spl, jic and kazama ends are much better and offer length adjustment for bumpsteer tuning on lowered cars. The tein inners seem ok, I havent bent one yet with serveral events on the same set.
Axel Grungy
Car: 2001 G20 5spd
sixxdeuce, your helmet is scary similar to mine lol. ive the got tein rods and am very pleased also. were twinkies
sil beer s13
Car: Kumori SPL S14
I use Peak Performance rods with KTS ends and have more angle then i know what to do with.
Not_a_sr
thats with stock 7spoke alloys and 195 60 15s up front. the car has alot of turning radius already . i couldnt see the use in much more
sixxdeuce wrote:Then you need to space the wheels out farther, aka lower offset wheels or smaller tires. The tein inners are same diameter as S14 inners so outers for both S13 and S14 are the stock S14 thread size. The ends really are not that good, just a rubber ball joint like stock, spl, jic and kazama ends are much better and offer length adjustment for bumpsteer tuning on lowered cars. The tein inners seem ok, I havent bent one yet with serveral events on the same set.
Fenvy
Not_a_sr wrote:thats with stock 7spoke alloys and 195 60 15s up front. the car has alot of turning radius already . i couldnt see the use in much more
for grip?
raging panda
Car: s13 coupe
the purpose for the extra steering angle is for drifting, being that this is the drift forum. Grip driving stock should be fine, although when you lower your car a lot, the spl ends should be used to correct bumpsteer.
Do you really rub the frame with your wheels/tires? Ive never heard of that problem, maybe youre rubbing the fender liner? Even with stock wheels, its shouldnt rub the frame, they never would have made a car that would rub itself, maybe your car is broken?
sil beer s13
Car: Kumori SPL S14
my car used to rub so i go out the hammer and move all the rubbing.
My wheels are 17x9+7 with a 215/40/17 ES100
raging panda
Car: s13 coupe
^^ right i had to do all that stuff, 17X9 +20, 215/45/17, but man, on stock wheels? I dont believe hes rubbing anything other than the inner fender liner.
sil beer s13
Car: Kumori SPL S14
^ same here. Stock wheel = ultra clearance.
Return to “Nissan Drift Forum”
