one ton garage »
https://forums.nicoclub.com/one-ton-garage-u17338.html
Fri Jul 16, 2004 7:11 am
Aftermarket tension rods like those give you improved steering feel and suspension response, in addition to allowing you to adjust caster (or in the case of a lot of older cars with worn out/leaking stock bushings, they will restore caster). They definitely do transmit a lot more road feel and vibration though, due to the heim joint-type rod ends, but I personally don't think it's that bad of a tradeoff in a car that already does a pretty good job of muting out all extraneous road vibrations and noise. If anything, most all stock Qs' stock tc rods are already in such rough shape that upgrading to such aftermarket units will only be an improvement
