Tein HE adjustability Help
robbbby
I just picked up some tein he's and they have a height adjustable mount. I've installed/used coilovers before but never ones with adjustable mounts.
I'm just curious where would be a good place to start adjusting it from? Should i thread the mount down so it is flush with the bottom of the shock body? Have it up a dozen threads?
Thanks in advance for any help.
sr20power
Car: S14 Zenki
i have tein HE's and they came with the factory settings...i just made sure that the setting were accurate and installed them.
i did my height adjustment after...i didn't have to adjust too much to be 25"in the front (ground to fender) and 25.5" inthe back....
http://www.tein.com/ti/inst/yn66u.pdfhere's the factory spec sheet for tein HE's:
http://www.cardomain.com/membe...l.jpga pic with tein HE's on:
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
Holy cow sr20power, your car looks GOOD. So are the HE's the way to go do you think? I might get an s13 hatch, and would be getting some Tein's. I'm not sure which ones to get though, as I have never researched them...
robbbby
Thanks alot for the english document!!
sr20power
Car: S14 Zenki
95silviase:Quote »So are the HE's the way to go do you think? I might get an s13 hatch, and would be getting some Tein's. I'm not sure which ones to get though, as I have never researched them...[/quote]it depends on what you want to do with her...in the beginning i wanted to go drifting, butgot introduced to auto-x'ing. so i used the little red button. it came down to JIC and TEIN's.i got a better deal onthe tein so i went with tho's
but if your just cruising around town or maybe some aggressive driving once in awhile, some shock and spring will do nicely
because there's a difference in $'s.....so do some research before you start to invest...
UncleBen
I need to research, and I have the spring/shock deal right now, which is good, but I have wanted some coilovers for a while. I thought about getting coilovers in place of my current suspension setup, but if you advice is correct, I may just stay with what I have.
