Tein H-Tech question
jhuerto23
Car: 2006 Infiniti M45
Can somebody confirm that the Tein H-Tech springs for the M35 will also fit on a M45? I just want to make sure it does before I order a set from Ebay.
Thanks in advance,
Jeff
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
They fit. I currently have them on my 07 45 Sport
jhuerto23
DoN_BLaZe34 wrote:They fit. I currently have them on my 07 45 Sport
Thanks.
TXT
Car: 2006 M45 Sport
This may be a silly question but dont you need to get springs specific for M45 or M35 due to different weight of the engine?
jhuerto23
TXT wrote:This may be a silly question but dont you need to get springs specific for M45 or M35 due to different weight of the engine?
I hope not. I just ordered em'
EniGmA1987
Car: '06 Infiniti M35 Sport
I think some companies make specific M35/M45 versions, not all do though. It will make a bit of a difference and the front will be lower than the specs say when used with an M45. The VQ35DE engine weighs 142 kilograms, the VK45DE weighs 236.5 kilograms.
I believe the H Tech's have spring rates of 7kg/mm in front and 9.2kg/mm in back? If so, that means that the front should sit somewhere around a 1/2" lower on the M45 compared to an M35. 13.5mm to be exact but I am going to round down a bit and call it a 1/2 inch.
jhuerto23
I will take pictures when I install them.
06M4.5
Car: 2006 M45
you'll have about a 1 finger gap on all 4 corners.
I have a set sitting in a box for about 2yrs now as my back-up springs.
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
does this affect the alignment I want drop my car but I cant afford to be replacing tires
06M4.5
Car: 2006 M45
lovemycarM35 wrote:does this affect the alignment I want drop my car but I cant afford to be replacing tires
you'll be ok with H-Tech
