Tein Flex's /w EDFC Rear squeeking problem.
Staticfree
Car: 96 240sx SE
Bout had my setup for about a year. The rear coilovers started making a squeeking noise when the car is rolling. I can also duplicate the problem by pushing down on my bumper but the squeek will go away after about 2 or 3 times pushing down. My dad suggested WD40 on my bushings see if that does anything. I did notice when it rains it does not make the noise. Any suggestions would greatly be appreciated.
static
jr_ss
Car: 95' S14
Wheel bearings have been known to make the squeak as well. My truck did that too, I took it to a mechanic and he said that the wheel bearing wasn't packed well enough. You might want to try that as a possible option as well.
Staticfree
Car: 96 240sx SE
ty ill look into it
Staticfree
Car: 96 240sx SE
bump
Staticfree
Car: 96 240sx SE
weres the 240 love?
crzycav86
Car: 93 Nissan 240SX KAT
jr_ss wrote:Wheel bearings have been known to make the squeak as well. My truck did that too, I took it to a mechanic and he said that the wheel bearing wasn't packed well enough. You might want to try that as a possible option as well.
I don't think the wheel bearings squeak when compresses at the bumper.
It's probably your coilovers. Mine squeak all the time, but it's the least of my worries. WD-40 might help, but you can also get a rubber hose that goes over the spring. It's essentially a bushing that stops it from squeaking.
Staticfree
Car: 96 240sx SE
yea my pops suggested that..i had thought my came with the bushing...ill have to check again. i have noticed less or no squeeking in the rain.
