gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Sun Mar 02, 2008 5:43 pm
Get you a brass or an aluminum drift. Basically a 1/2"- 3/4" piece of rod maybe 6 to 8" long. The metal you use for your drift can not be harder than the metal used to make the lock rings, which should be aluminum.Use a hammer and the drift and start tapping that bad boy in the appropriate direction. Righty tightey, lefty loosey.Don't go Hulk smash with the hammer, but don't be a wuss either. Use controlled moderate strokes.
