TEIN Coilovers now released..
General discussion area for the L32-chassis Altima
scrutmonkey
Car: 08 Altima Hybrid
Here is the thread from Nissanclub.
it seems it's only for the 3.5L, sedan and coupe right now.I'm repeating Flores's post from Nissanclub.
TEIN Super Street Coilovers finally out!!For all of those people that waited soooooo long they are finally here. $1660 though so I hope all you guys saved, pretty pricey!!. They are avalible for the Sedan and Coupe.
TEIN USA
NISSAN ALTIMA SEDANL32 07+ SS 3.5 FF 4dr DSK10-KUAS2$1660.00 6/336S8K10-0U060 8/448S6K11-0U080 OEM -39-1.5 -25-1 -29-1.1 ~ -54-2.1 -2-0.1 ~ -47-1.9
NISSAN ALTIMA COUPEU32 08+ SS 3.5 FF 2dr DSK10-KUAS2$1660.00 6/336S8K10-0U060 8/448S6K11-0U080 OEM -40-1.6 -43-1.7 -30-1.2 ~ -54-2.1 -20-0.8 ~ -70-2.8
Description:TEIN Super Street damper kit was designed for drivers seeking improved handling on the street and at the track. A shortened shell case is utilized to allow the most piston stroke possible, which allows for a better ride at lowered ride heights, and increased grip at the track. Great for daily driving and occasion track use, whether it be at the drag strip, local circuit, or Auto-X course. Includes both ride height and damping force adjustment to allow the driver to dial in the suspension for various surface conditions.
Additional Features:• Steel Construction• Twin Tube internal construction• 16 way adjustable dampers, compression and rebound combined• Ride Height adjustable via spring seat• Larger piston diameter for strut type front and rear (22mm)• Powder coated damper body with Zinc coated threaded section• 1-year Manufacturers Defect Warranty• Available for Overhaul+
http://www.nissanclub.com/foru....html
Return to “4th Generation Altima Sedan (2007-2012)”
