Tein coilover question
dtowndrifter
Car: s-14 kouki
hey ppl.. I have these tein super streets an i want to go lower with these ..But i've already maxed them out...I was looking at the tein website an tjey sell two springs you can replace the coil springs with..a standard spring an a racing spring..will the racing spring provide more drop? or what?
I have the standard spring that my super streets came with..here http://www.tein.com/products/standard_spring.html
then theres these you can buy
http://www.tein.com/products/racing_spring.html
do these provide more of a drop? i'm already maxed out^^^
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
the "racing" springs probably just have higher spring rates (stiffer).
Frank E Bones
Car: Slower than it looks
I have the same suspension on my car and was wondering the same thing myself. So from what I found out (Directly from Tein) is that you really cant go any lower on that application without negatively affecting the shock. They recommend upgrading the suspension to something that was designed to go lower, like their Super Drift or Flex Coilovers. Even then its only a difference of about .4"
Modified by Frank E Bones at 11:01 AM 12/10/2009
Gabes13
Car: rb20det s13
Go outside and measure two things.1. The spring length 2. The spring Diameter
I bet its 7+ something inches tall and has a spring seat diameter of 65mm
If so, you're in luck.
They have a 6" spring, but you'll have to bump your spring rate to 8+
I really don't know what the longevity the coilovers would be with those springs because the bottom mounts aren't adjustable.
