TEIN Coilover Kit in Progress for us 4th Gen Sedans
General discussion area for the L32-chassis Altima
Beantownz_Nissan
Car: 2007 Altima
How are the BC's holding up?
jungleboogie
Car: '08 VQ35DE Sedan -- Winter Frost w/ Black Leather
mcheddadi wrote:lower the damper settings, on my bc racing ones I'm at 6 soft. when I track on a perfectly flat course i go to 32 on a not perfect track I go to 16.
whats the rate of the springs?
took a while to get this info but the specs are roughly as follows:
Spring Rates:Fronts 6kgRears 8kg
Ride HeightFronts 355 (-40 drop from stock)Rears 345 (-25 drop from stock)
Ride Height AdjustmentsFronts -29 ~ -55 from stockRears -10 ~ -47 from stock
As stated in a previous post, the rears are virtually inaccessible without lifting and taking apart the entire assembly (prototype only) and the fronts are the only ones where easy adjustment is possible. The ride so far seems somewhat stiff and i've already bottomed out several times on speed bumps.
socal_alti08
Car: 2008 Altima Sedan
Do they have "Front Camber adjustment" in the front as the BC Racing Coilovers have?
Return to “4th Generation Altima Sedan (2007-2012)”
