Post by grahambrowne » https://forums.nicoclub.com/grahambrowne-u41049.html Fri Jun 16, 2006 4:45 pm
Post by Gsedan35 » https://forums.nicoclub.com/gsedan35-u15650.html Sun Jun 18, 2006 2:49 pm
In general Tein has a +or- 1Kg amount of play build in to the basic coilover to allow you to go up or down by that small amount. In the end contact Tein directly at 1-562-861-9161 and ask one of their techs to be sure.grahambrowne wrote:whats up, Ive had TEIN basics on my s13 for 2 years now and Ive decided to swap the rear springs to 5 kg/mm as compared to the 6 kg/mm standard springs. Its just too stiff for street use. because the dampening is non adjustable, how will this impact the handling? should I re-valve the shock? also, where would I get 5 kg/mm springs?
thanks- graham
Post by grahambrowne » https://forums.nicoclub.com/grahambrowne-u41049.html Mon Jun 19, 2006 12:14 pm
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
