tein basic coilovers...
240wootie
Car: 1989 rb20 coupe, 2002 WRX
So i went to install my basics today, and i must have the wrong mounts for the rears? my question is are there two different mount types for the rear coilovers? the ones mounted on mine are clearly too wide to fit up into the mount tunnel. and i already sold my kyb/tech-s setup so i cant swap the mounts over from those. i've been searching aroud for an answer, but i havent seen someone who has the same problem.
gumby74
Make sure they are not for an S14.The rear shocks are longer and the mount spacing is, as you have just discovered, wider between a 13 and an S14.
240wootie
The coilovers themselves are for an s13, but i'm thinking that the upper mounts are s14..? i have no idea why.. anybody have some stock s13 upper rear mounts they want to get rid of?
