deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Thu Jul 01, 2004 4:38 pm
Check out ztechz.net if you havent already. The dohc ecu can work as well but its much more involved than sohc. It requires a custom made daughter board and other parts, but it has the advantage of possible consult operation. There are a few nissan consult/emulator programs and hardware available, this allows to change all variables in real time, ie full control (and better/cheaper/easier than most standalones).
Only thing needed for itb with turbo, is a fully sealed and pressure tested plenum to join all throttle bodies. You would then just configure turbo setup like normal, with some tuning it could work quite nicely. A mini rb26.
Regular short runner custom intake manifold all in all would be much more simple. But then its not itb.
That standalone im using can be configured/tuned for ITB turbo easily.
