ACESXX wrote:--> I know that is gonna sounds stupid..... but have you change or checked the oil?
ricky240sx wrote:" ... i just got an oil change. ..."
--> sometimes you get unsuspected leaks and more than usual on an turbocharged engine.., you could be pouring all that new oil somewhere whenever you hit the gas...!!!ricky240sx wrote:...i just got an oil change.
he also said that he's running dc headers on a sr20det, you can't have it both ways. and afaik dc doesn't make a manifold for the sr, just headers for the ka.ACESXX wrote:--> sometimes you get unsuspected leaks and more than usual on an turbocharged engine.., you could be pouring all that new oil somewhere whenever you hit the gas...!!!
Ummm, no. I'm assuming you're trying to say he's burning oil but that's not the case. If he was, it would be blue smoke, not black.ACESXX wrote:
Easy way to check, with the engine off pull the intake tube off the compressor side of the turbo. Grab the compressor wheel and push in and out, and side to side. If there is a lot of play you need a new turbo. But that wouldn't cause you to run rich (which is what black smoke means) but it would cause you to burn oil. Double check on the color of the smoke. And if it's the turbo there will only be blue smoke coming out the exhaust when you go WOT.ricky240sx wrote:well its a dc manifold, ill check today bout the oil issue...later today...i wish it wasnt 110 degrees out here...one of my friends say i have a blown turbo... would you agree
