Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sun Feb 06, 2005 12:44 pm
don't see how it could since chain is kept away from the block walls. Also, if it were able to rub up against the wall, you'd have bigger problems. Namely broken chain guides and chain that's stretched so much, you shoulda blown your motor.
More than likely it's head gasket. You may have a small minor leak where coolant has been able to seep into one of the oil passageways, but hasn't blown out into the combustion chamber yet.
