Technical Issue S15 front conversion
JamesLeeNguyen
Car: 1989 NIssan S13
I've been trying to figure out the pros and the cons of doing the s15 front end conversion with the s15 radiator core support and without it. My main question is can you do it without the core support? There are many guides on doing it with the core support but none without it.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
An S13 requires the core support swap, but it can all work with some fabrication (easier to swap core support). S14s can be swapped with the existing core support by just drilling two holes for the upper headlight mounting locations and cutting two relief holes for the projector housing clearance on the zenkis. The kouki models already have the projector relief holes, so they would only require two holes drilled for the upper headlight mounting ears.
