JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Mon Jan 20, 2003 7:30 pm
I was just wondering if anyone knew exactly why putting SOHC pistons into a DOHC motor raises your compression so high? My 90 8.6:1 pistons have a slight dish to them, and i believe the 89 9.1:1 pistons are flat top. The dimensions on the SOHC and DOHC blocks should be identical, right? But if you drop 8.6:1 SOHC pistons into a DOHC block, you get 11.1:1 compression ratio, right? So is it the size and/or shape of the cylinder head combustion chamber? I believe my 90 SOHC cylinder head combustion chamber volume is 60cc's. If anyone has a technical answer, i would love to hear it.
