180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Jan 22, 2005 1:55 am
power steering - use ATF. Don't know of any oil that'd blow apart all the seals in a power steering system. using the right stuff or something else was at fault.
did you bleed them correctly? Are your rear calipers seized? Do the brake pads have enough material on them? How are the grooves shaped? Is it a groove that seems to show up in the same area on the entire rotor oh about 7 or 8 mm in height and runs the entire rotor surface in a circular shape? A better description with pictures would help.
