beetlebob »
https://forums.nicoclub.com/beetlebob-u188194.html
Fri Jul 29, 2011 5:04 am
HELP I have a 7/03 G35 that if you push just a little on the gas feed at 40 mph it down shifts 1 to 2 gears lower and if raining will cause the tires to come loose under car. It has no codes in all places I can read. I have a Modus Snap-on scanner with the newest updates on it. All I can read is line pressure at idle stays at .6 volts. It will drop down when put in gear and power brake little but can not find out what reading are correct to see. Can not find any TSBs on a shift problem. Car has 76,000 on it and do not know if trans has ever been serviced. Beside this the car runs great. Thanks for anything anyone can send.
