eww. any mods?Craig Brumley wrote:"Brake", "VDC OFF" and "SLIP" lights are on intermitently. Started Tuesday morning, Tuesday evening the battery had to be replaced. It seems to only be happening in the mornings after I've driven a few miles, on the way home in the afternoon, no problems. Any ideas?
g35-how-to-reset-ecu-throttle-pedal-rel ... 56397.htmlCraig Brumley wrote:How do I perform the ECU reset?
That seems to have been the issue. The level was just above the "MIN" line. I topped it off, and it hasn't happened since. I think the battery dying was just a coincidenceRED_DET wrote:Check the brake fluid level, it low it will throw those lights. If the brakes need replacing, it will throw those lights as well.
joe603 wrote:Nice fix man!
