word on that.. i've tried everything.. my last resort is going to be heating it up with a torch then letting it cool down so it might break free..Secret squirrel wrote:i havnt even gotten my damn crank pulley off yet, so atleast ur 1 step ahead of meSS
I was there at this same damn crank sprocket a while ago and i agree with this man! Deffinately try this method as i and others will agree it is an easier and safer method! I put anti-sieze lube on my new sprocket to help prevent this during the time i own the engine.jt15833 wrote:i tried a bunch of different things w/ heat and cutting but i found the best method was drilling and tapping two holes in the front face of the cog 180* apart. then using the right size bolts and a slide hammer pulled it right off. very safe as well.
You should listen to this guysuperJoy wrote:I ordered mine from http://www.onlyfactoryparts.com for $23.05, as stated above.
