Team Pwncaeks
BoyWonder
Car: '93 Nissan 240SX S13 Convertible (reclaimed... wootles)
Well, if we finish ours before you do (including wiring), and our other 2 pending projects, I wouldn't be against lending you a hand. We'll see how much progress we make, though. Blake still needs to get a few parts before we can reassemble his engine and drop it in.
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
like maybe an oilpan...
SeVa-S13
Car: '05 GTO 6spd
Ahh, but our boy there told me the fix for that. :) What I actually need is a clutch. =\
[Zero-S]
That should be taken care of very soon tho;)
You's a pimp, son.
Project240
Yep, $15 or so and your oil pan's like new :) I got my clutch off Ebay, ran me about a hundred bucks. I figure I'll be fine with a stock 300ZX N/A clutch for now, considering it was intended for a much torquier 3.0L motor rather than the 2.0L motor it's going on.
BoyWonder
Did you get the belt measurement you needed, Blake?
SeVa-S13
Car: '05 GTO 6spd
That would be a no...
Mr1der
slackers...
get the job done son!
SeVa-S13
Car: '05 GTO 6spd
Trying to decide between clutches.Right now, I have about $800 to spend on bits and pieces for the swap. I'd LIKE to do some sort of a clutch upgrade but that costs quite a bit. $330 from P2M (Exedy RB25 clutch) rated at 372ft/lb or $285 from HorsePowerFreaks.com (ACT NA 300ZX) that's rated at "59% Torque Capacity Increase." I have no idea what that works out to but we'll see. But then there's an OEM NA 300ZX clutch kit on eBay from high rated seller for like 93 bones. I'm kinda leaning towards that because well, I'm a poor white boy.
Hopefully, the clutch, and timing and AC belts will be ordered by tonight.
whoflungpoo
Car: 2006 Infinity G35 Sedan
2003 Evolution VIII
I know where you can get a 6 puck and pressure plate, an OEM, or a centerforce copy for a good price... it's a guy local here in louisville who rebuilds/manufactures his own, but i'm sure he'd ship one to ya.
it's called Kentucky clutch, here's a link with the phone # and a map too... -CLICKY- He's got a very heavy southern drawl, but he's real knowledgeable about his stuff. it's at least worth checking out.
I've got an OE style clutch of his in my 240, and I know the DSM guys around here use the hell out of the 6 pucks that he makes. If they'll stand up to AWD launches, they're okay in my book.
BoyWonder
Good lookin out :thumbup
SeVa-S13
Car: '05 GTO 6spd
My whooping range has been effectively quadrupled. (Hardcore cardboard rolls from the vinyl we print on at work. They often get used in co-worker jousts and sword fights when there's no boss to be seen.)
And yes, the post serves a purpose--you just have to figure it out. :batman
jdmfreak
I give up. What is it?
Mr1der
he's in the process of hooking us up with discount vinyl graphics?
if not, I'm so gonna beat him with sticks while wearing some tv boxes...
[Zero-S]
Yes...there we have it. Blake is a goofy mofo.
AceInhole
hmm... i find this thread AFTER i crash my car (which was named "pancakes")... the irony
Mr1der
You didn't flip it did you?
jdmfreak
LMAO!!!!
BoyWonder
Progress is being made..and pulling a transmission from under a car is very unpleasent.
Project240
Not quite as unpleasant as making the mistake of lowering the entire RB driveline in from above, instead of raising it from below, and dealing with all the s*** that comes along with it.
Trust me on this one ;) :(
BoyWonder
So you're saying lowering wasn't fun? I'm not sure how we'd do it any other way really.. given the tools we have to use.
Project240
One problem with lowering it in is that you have to position the chains *just right* on the engine, so that when you put it on the hoist and lift it up, it sits level, the way it's supposed to in the engine bay. Consider the fact that you have an engine and trans lifted high up over an engine bay that's already a little too small to accomodate it, and you're angling the whole driveline downwards at like a 45 degree angle as you drop it into the bay; you have to drop it an inch, push it against the firewall, drop it an inch, push on it, etc etc. Even with the driveline pushed up against the firewall as we were dropping it in, the crank pulley took some coercing just to fit past the body where the radiator bolts on.
Basically, it's an extremely tight fit. It took us well over 2 hours just to drop it into the bay. If the engine's leaning to one side at all, you will not be able to line the mount bolts up to the holes in the crossmember. Plus, it is WAAAAAY too easy to crush stuff this way; we crushed a power steering line where it enters the steering rack, and now I'm gonna have to go back, cut it off and reconnect it with high pressure line. Add to that the hernia that I almost got standing on top of the car and pulling up on one side of the motor to get it level just so the bolts would fall in, and it's just a hell of a lot more trouble than its worth.
If I were you, what I would do is use the engine hoist to lift the front end of the car up really high, slide the driveline under the car, and lower the car onto it. Once the car's low enough, set it on jackstands, unhook the engine hoist, and use the hoist to raise the driveline into place and bolt the crossmember to the frame. This doesn't require any more tools than if you dropped it in from above; me and my friend pulled it off in my driveway (the more difficult way) with nothing more than a hoist, a couple jackstands, a pep boys $19.99 floor jack and some boards :)
BoyWonder
Sounds like great.. fun? An outdoor project, I think, since I doubt my garage is high enough to allow the car to be lifted up that high. Taking the rack and pinion out isn't something I'm really looking forward to though.
Project240
Can you push the car out into the street? It's too nice outside to be working on a car in the garage if you can help it ;)
BoyWonder
The car has been in the street for awhile now.. we needed somewhere to put the clip, and work on the other car :DUpdate on the vert: As soon as I can get this transmission from Rob, pick up the resurfaced flywheel, and drill a hole for the master cylinder, I'll be set. New Clutch, Pressure Plate, throwout bearing, master cyliner, and slave cylinder - just a used hard line and transmission.
roro240
Car: making beats,anime,skateboarding,computers
meet the latest member... me
curteousy of my brother chris lol.
im jes being a ninja and watching in the bushes.
C-Boogie
Car: '00 Nissan Altima
'92 Nissan 240SX S13
I order you to wash the cars. All of them. Haha own3d. j/k
roro240
sure seriously... ill wash them... for a price lol
JESTER
Car: 2004 Chevy Colorado Bright a** Red 3.5 five cylinder
Okay, I make a motion that AZ makes your rabbit our offical mascot.
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
I saw the pancake wearing rabbit on fark.com long before I saw it here. Not sure of the origins of it, but you just have to laugh.
