carmo wrote:zerothread?id=351373
This is my VQ swapped s13 build thread. I'm curious to know how you intend on installation. You may be about to use a company that I would highly recommend against. Well, for certain things anyway.
Ive glanced at your build, but I havent gotten a chance to sit down and look through it all.
As far as my build will go. I Just got my new 240 shipped up here (to WI) from FL. It is rust free, but ugly! LOL. I wanted to use a Z engine but those go for 3K and to me thats just a rediculas price. So i plan to use a VQ from a 03 maxima. I will use a 04 Z transmission. Z oil pan, Z flywheel and clutch, Z starter. Modify the Z transmission shifter linkage to be shorter to fit. The maxima has a different mounting location then the Z so my motor mounts will be different then normal. I was gonna take it to a shop to have a custom drive shaft made. My friend and I are gona make my headers.
That will get it in, but to make it work, that took alot of research. I was gona use megasquirt but that wont work with the VVTC or whatever the variable valve thing is called. So that was out of the question. Then I was gona use the Stock ECU. But mine is gona be a push bottom start so i dont plan to use the Key. Also i didnt want to have to deal with NATS in the ECU, so that wasnt an option either. Then i was gona use a good EMS, but i really dont wana drop 2k on a AEM standalone. So i just found out about Jim Wolf Technologies. I called them and told them what im doing. I asked them if they can reflash the stock ECU to run without NATS and all the extras. I just wanted the bare minimum, plus the VVTC. They told me to get a 96 maxima ECU, and that has no NATS, and they will reflash it to the bare minimum, but make it run for a 3.5L VQ motor instead of the 3.0L VQ motor. They said they can also give it VVTC. They already gave me a wiring diagram on how to wire it up any any car. All that for $600. I dont think thats to bad for a plug and play
