TE37 sizing and offset for S13?
mac11
Car: 240sx
Please help me on off-set.I want to buy TE37 for my 180sx and I dont like alot of bodywork or cutting rolling ect cause is my everyday car.And on spec wheels someone post a 17x9+22 all around whant to know if there a wheel spacer but the pic was long gone dont know if 5lug.I have 92hb w/ Z32tt 5lug on front and s14 rear.Please help on tire size and advice on TE37 PIC will be so good to see how nice.Thanks
turbo2nr
Car: 97 240sx (kouki)
i personaly thing the 17" te37 look to small, the 18" te37 look better, the spoke curve in more may be 18x9 with a offset in the 20..
SeVa-S13
Car: '05 GTO 6spd
Moved to the proper forum.
Oh, and welcome to NICO and go easy on the question marks.
whiterps13
Car: white LE hatch
Actually a 17x9 +22 will be the closest thing to perfect if you want flush wheels with minimal work. You will have to perform a minor fender roll, but its worth the look. Running a 225/45 with this setup will be great.
McRussellPants
Car: 92 240SX
17x9 +22 is what Benson used to run on his Sil-80.
Its perfect on a stock body S13. Perfect.
phuphyter
Car: 2002 Infinity G20
McRussellPants wrote:17x9 +22 is what Benson used to run on his Sil-80.
Are they 17x9 +22 all around?edit: whoops. sorry benson. (linked to his picture)
Modified by phuphyter at 5:26 PM 5/1/2006
Juujai
yeah 2 choices, 17x9 +22 or 17x9 +15 if i remember tire sizes ia lways recommend goign with 40 series unless its 215. 225/45/17 is like 1/2 inch taller than 235/40/17. especially with stock body 240 you need it as low as possible. the front bumper clearance on our cars is very big... 10 inches stock even dropping the car 4 inches the bumper gap will still be about 6 inches so no worries... every 1/2 inch counts
depending on what camber you want to run choose either or. not sure if the 22 will clear your coilovers but thats for you to figure out.
