TDC Timing trouble help please
failwagon
Car: 91 s13 se coupe
ok the crank is definately at tdc on cylinder 1. its at the 2nd mark on the pulley and i checked with a screw driver.the timing chain skipped a tooth a couple days ago and that's why i'm fixing it until i can throw another kit oni think this timing in correct except i still couldn't get the motor to start. distibutor had the rotor pointing right at the first cylinder plug wire.
i guess its possible i have bent valves but that wouldnt stop the motor from running. just a compression loss right?
any help is much appreciated.thanks guys
