XxBLiNdxX »
https://forums.nicoclub.com/xxblindxx-u27987.html
Mon Apr 25, 2005 9:52 am
I've read through pretty much every TDC thread in these forums and have not seen any pictures of TDC for KA24E, so here goes some. Only problem I have is Distributor is set at number 2 when my book says to set at number one. On the contrary the book shows a picture of the distributor at firing location #1 set on plug 2. I have the crankshaft pulley timing mark set at the second notch from the left(0 degrees). Also can someone verify that when piston #1 is up, you cant stick anything past the length of the spark plug?Sorry for the long post here are the pictures and thanks in advance.
