Dante »
https://forums.nicoclub.com/dante-u8113.html
Thu Jul 24, 2003 5:02 pm
I've done a lot of searching and sifting on this, and I'm still a bit confused.
I need to make sure my #1 piston is @ TDC. This is what I've heard is the way to do it: Make sure that the notch on the inner part of the cam sprocket is vertical, with the dot on the edge of the sprocket @ 3 o'clock, and the silver link in the timing chain lining up with the dot.
I rotated the crank quite a bit, and the silver link comes within one link of lining up, but doesn't line up exactly above the dot. Have I not rotated the crank enough, or is it even necessary to have the chain line up to make sure it is at TDC? If I haven't rotated the crank enough, how many rotations of the cam sprocket are in a full cycle?
