Okay wrote:Im installing the timing belt but how do you set piston 1 to TDC? Do you just align the marks on the sprockets to the marks behind them? I read that you put a screwdriver in the #1 cylinder and crank it until it's at the top. Also, I turn the crank seperately from cams when I put my clutch on...is it ok to do that?
It's not okay to turn your crank seperately from the cams. You run a risk of jamming the valves into the pistons. As for setting your timing, this section is covered extensively on this forum. But as a quick reference, the cam gears has timing marks on them and they must be aligned with the marks on the black cover behind the cam gears with white marks on it. Temporarily install the crank pulley, make sure that the cam marks are in the vicinity of where I told you they should be, rotate the crank until the orange mark or the 2nd mark from your left if you're facing the pulley is line-up with the pointer with the white line on it which is on the lower timing cover. If you do this correctly, you should be fine and so should your timing.
Dee
