Thanks for the explanation! I appreciate that! Since I can't see the oil pump gear because I have the timing chain cover on, I will reference the timing by using the screw driver, Cam sprocket, and the distributor.
Here's the thing... I heard what sounded like a rattle in all RPMs. It's not the tensioner because I verified. So I assume it's a lifter so, I pulled the valve cover off. All the rockers are nice and tight, except for two on the intake side that are compressed. So I assumed the lifter might be stuck but, someone here said it might be the exhaust manifold. Sure enough, there are two bolts missing right under the valve cover on the exhaust side. So, to avoid messing with the rockers and lifters, I want to verify from someone that the rockers' positions are normal based on the pic below. If they are, then I can focus on the exhaust bolts and see if that is what's making the tapping sound.
Can anyone verify that my valve train looks normal?
I would appreciate it so I can move forward as soon as possible.
Thanks in advance!
