the 200sx has a distributor and to find top dead center it refers to cylinder one so the rotor should point down towards the master cylinder thats the #1 terminal on the distributor cap..... as far as top dead center the #1 piston is up and on the way down or before compression strokejoewardjr wrote:According to the Haynes Repair Manual for the 1995 Nissan 200SX TDC is when the rotor tip is pointing at number one distributor lead and the timing marks are aligned with the "T". Which side of the rotor tip are they referring to? You have the abrasive end and the non-abrasive end. Can some one explain? Help
Modified by joewardjr at 3:59 PM 1/27/2008
