tdc help
m1dt0wn3
hey guys i'm tryin to set the crankshaft to tdc but every time I try there is a resistance that won't let me crank it. Its like a springy kinda feeling but its not a spring. Does anyone else have this problem or am I not cranking hard enough?
fuzion
Car: Cars.. Web/graphic design.. Yuppp
Uhm... Compression? Are all of the spark plugs out?
m1dt0wn3
yeah all of them are out and its still doin it
DAEDALUS
Car: 1990 Infiniti Q45
Is your valvetrain assembled? I.e. are your camshafts turning with the engine? Maybe valve springs pushing against the cams, pulling against the crank?
DAEDALUS
Hopefully not valves pushing against piston!
m1dt0wn3
no man the valves are good not hitting...and I'm pulling the crank
BadMojo
Car: 2007 Mazdaspeed 3
It wasn't exactly easy to do flat on my back under the car, but I just turned the thing. It was easy enough to turn with one hand, though there was some resistance.
DAEDALUS
The valves aren't hitting, but are they moving? Is your valvetrain assembled??? Are your camshafts turning too???
