TD06 20G & 650cc's...
andrewdees
Car: 97 Emerald Green SE
Hey guys I may be purchasing a TD06 20 G. I have a Blacktop SR with a FMIC and 255 fuel pump. Would an AFC be good enough to tune the turbo with 650cc's? What kind of boost and power levels would I be looking at? Thanx
-Drew
Papo240
Blacktop SR with TD06 20G walbro pump, Apexi SAFC, 750 injectors. 280 WHP @ 11 psi
andrewdees
what manifold are you using?
Do you think 350whp is possible with a Z32 MAF, 650cc's and the AFC?
thanks!
-Drew
Poor_S13_Driver
Car: S13
Why would you want to trust a SAFC with that big of a responsibility?
andrewdees
Im not too familiar with the AFC's and didnt know how much power the were good up too. Maybe it would be safer to have an ECU burned for my setup?
Morph
Car: 91 Sr Powered Coupe
Anything that much get a retune or a standalone.
Poor_S13_Driver
Car: S13
No problem man, gotta learn somehow. I myself dont really know much abot SAFC so i shouldnt have commented in the first place. However i believe the SAFC can only handle up to 555 injectors..( I may be wrong). Also from what Ive heard and or understand, anything close to or over 300hp you really want a tuned ecu, or a standalone to have consistent reliability (Im sure thers exceptions, this is just from what i have read/seen) someone else will chime in with more info im sure
Ineed2speed
Car: 1997 Nissan 240SX SE
Papo240 wrote:Blacktop SR with TD06 20G walbro pump, Apexi SAFC, 750 injectors. 280 WHP @ 11 psi
More info on your setup please? Got a dynograph? I'd love to see
Emperor_Tha
what turbo manifold are you using and downpipe. i was thinkin of using the evo viii 18g since i can get it fairly cheap from work
Logan76
Car: Junk
I thought the Evo III had a Big16G?
Emperor_Tha
Logan76 wrote:I thought the Evo III had a Big16G?
yea but teh evo viii(8) have the 18g
Logan76
Car: Junk
Har Har I messed up my roman numerals not paying attention, my bad.
Emperor_Tha
its cool, but do know know what turbo manifold i should used? maybe the same one as they used with gt30r??? i can probably make my own downpipe.
fregisr
Car: 240sx 1990
safc will only allow you to go 50% over the stock injector roughly around 550 ish. You will need a programmed ecu.
massholeS14
Car: 96 built sr'd s14
? where are you getting your info from? the evo 8 has a big 16g as well. it is a similar size as an evo3 big 16g with the exception that the evo 8 turbo is a twin scroll setup.
massholeS14
fregisr wrote:safc will only allow you to go 50% over the stock injector roughly around 550 ish. You will need a programmed ecu.
yeah tuning injectors over 550's on a safc is pretty rough, it might be possible but you wont see anywhere near the potential of the car that you should.
