TCU
HG50
Car: 91 Q45
15 4Runner
ok well after searching and also not being able to use the search for multiple searchs here we go.
as some of you know i did a jdm motor swap on my 91 q. Now i want the 1st gear start tcu that was avail. later on. i did have the part numbers 3 months ago while i was looking around but seem to have lost it.
hope that some of you will be able to help me out.
also if you know what year sway bar i can use from the active q45 if it matters.
thanks again,
chris
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
There was an update on the 1993 TCU. So get the later one. It is in the posts somewhere.
Any rear a bar will fit, but you will need brackets and links if one isn't in place now, and likely rubber.
HG50
Car: 91 Q45
15 4Runner
THANKS BUT THAT DIDNT REALLY HELP. THE SEARCH DOESNT LET ME DO MORE THEN 1 SEARCH UNLESS ITS ABOUT 15 MINS APART.
NO ONE HAS THIS PROBLEM. EVEN AT MY HOUSE COMPUTER IT DOES THE SAME THING.
SO DOES ANYONE KNOW THE PART NUMBER/S THAT I WOULD NEED.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
zerothread?id=166982
I dont understand why you couldnt come up with that thread? Interesting.. You serached THREAD BODIES, not just thread TITLES, right?
elwesso
2007 BMW M Coupe
HG50
Car: 91 Q45
15 4Runner
wow well it only took a few mins for my reply to show up and bam you have already replied with another one of your smart replies. really appreciate it thanks!!!!!!!!!
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
saw a tcu on e-bay seller alexlikeslife or something like that, he is cool and will sell cheaper than listed befor any action starts.
Rex
Car: None
HG50 wrote:wow well it only took a few mins for my reply to show up and bam you have already replied with another one of your smart replies. really appreciate it thanks!!!!!!!!!
?? I'm somewhat confused, the threads Wes linked to have part numbers and other various information about the early trannies and TCU's. Is there something missing?
HG50
Car: 91 Q45
15 4Runner
dont really want to reply to him again. i guess being a moderator takes a toll on you having to be on here alllllll dayyyyyy longgggggg.
ill look around and hopfully buy the right one.
but if you know something i dont let me know. im also gonna check that guy on ebay also.
chris
elwesso
2007 BMW M Coupe
IM confused? I tried to help out? Is that not good enough?
Q451990
maxnix wrote:There was an update on the 1993 TCU. So get the later one. It is in the posts somewhere.
There were two TCUs for the 1993Q - which is the only one with the 90-93 geared transmission that came from the factory with 1st gear start. They factory unit ended in 60U20. The 60U75 was a counter-measure TCU that was installed to reduce torque convertor shock in vehicles built before 2/1993 (VINS ending in 250083 or before).
The TSB is ITB94-023The countermeasure part numbers for 1991 and 1992 models (2nd gear start) ended in 64U70 replacing 64U11 and 64U12 factory TCUs. Apparently this wasn't an issue on the 1990 transmissions.
I have never seen or heard of anyone finding or buying a 64U75 - so the 60U20 is what you will probably find out there in junk yard land...
Heath
Rex
Car: None
HG50 wrote:dont really want to reply to him again. i guess being a moderator takes a toll on you having to be on here alllllll dayyyyyy longgggggg.
chris
Copied from a post in one of those threads ...
"The TCU you want is from a 1993 model year with part number 31036-64U20 or 64U75. Later 94-96 TCUs will work too, but the transmission in those cars are geared differently than the one in the 90-93. For best results having the matching ECU is a good plan... you tend to get better redline shifts..."
Hope that helps.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:IM confused? I tried to help out? Is that not good enough?
Heck no! You didn't masticate it for him, you ingrate!
66mgb
Car: 1992 Q45 Modified w/ NICO Goodness
I just picked up a TCU (68U10) for my '92
Does this TCU have 1st gear start? This thread sounds like I need a 64U20or 64U75
Thank you
Modified by 66mgb at 4:14 PM 6/26/2006
66mgb
66mgb wrote:I just picked up a TCU (64U10) for my '92
Does this TCU have 1st gear start? This thread sounds like I need a 64U20 or 64U75
Thank you
Well I installed the 68U10 and almosed fouled the drivers seat! 1st gear start really woke up my Q. I can't wipe the smile off of my face. Now I just have to train my foot to ride a little lighter. 1st gear goes to 3200 rpm now and when 2nd kicks in it jars you back.I haven't put it through it's paces yet, since my 3 year old was riding with me. He said "Daddy this is a hot wheels car!"
Anyone with the 64U20 or 75 care to comment where the shift points are?
Modified by 66mgb at 4:16 PM 6/26/2006
