TCU?
STATUS
Noob here. I did a search and i could not find anything about the TCS situation. How do i know if a car has TCS or not? The car is a 95 Q. Its a Non-touring. Any help would be greatly appreciated. Thank you.
****EDITED****
Modified by STATUS at 12:13 AM 3/3/2006
Raxephon
Car: '04 RX8...for the moment...
TCS= Traction Control SystemTCU= Transmission Control Unit(Module)
All Q45 automatics have a TCU.
Some Q45's have TCS.
Which one are you talking about?
STATUS
HAHAHA! My fault! It was TCS. Sorry its been a long day!
Raxephon
Here are some of the components pictured in the '95 FSM.(BR Section)
STATUS
Awesome! Thank you very much. Thats exactly what i was looking for.
Raxephon
You're welcome.
Just in case you don't have an FSM......
'95 Q45 Factory Service Manual http://phatg20.net/modules.php...d=204
STATUS
WOW, that was the next thing i was looking for! THANK YOU VERY MUCH.
STATUS
So the car does not have TCS. Is this a good or bad thing? Thanks.
Raxephon
STATUS wrote:So the car does not have TCS. Is this a good or bad thing? Thanks.
My '91 is a base model, so no TCS or Active Suspension.
Would I install the TCS if I had the parts laying around? No. Less weight and fewer problems to deal with.
As far as detailed positives/negatives go, you will have to wait for a member who has/had TCS on their Q to chime in.
Q45tech
TCS is not necessary IF you operate with the proper tires for the season --------soft fast wearing enough. TCS can be dangerous with hard aftermarket tires, pulling out from a stop, the sudden bog can get you rear ended.
STATUS
OH ok sounds good. Its good to be use to the rear end going out. Counter steer baby! hahaha. Thanks guys! You guys are great.
