tcu swap questions please help!!!
jettsetter4life22
Car: 1990 infiniti q45
ok so im trying to find a 1st gear start tcu for my 90 q45. i see all these wolf made tcus for x amount of dollars i want to know whats the difference between getting one of these nico ecu's tcus whatever or just going down to the junk yard and taking a tcu out of a 93+ model q45 and having 1st gear start? any info will be gratefull.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Ther are no NICO TCU. JWT quit making TCU, except maybe by special order if you have a lot of time.
Get the 1993 TCU. In the posts here, you will find two part numbers for it.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
31036-64U20 I believe.
jettsetter4life22
thanks for the help ill go to the local u pull it and grab one now. Now I thought though that the NICO ECU's took care of the 1st gear start. If it doesnt what excactly do these NICO ECU's do for my baby and are they worth getting in addition to a 93 TCU? Thanks guys this forum is great! you guys rock
bryan
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The NICO ECU runs a little leaner with a little more advance above 2500 rpm.
Don't even bother until you have rehabilitated your engine to as new OEM specification.
Haitian_King
maxnix wrote:The NICO ECU runs a little leaner with a little more advance above 2500 rpm.
Did not know about that factoid. Thanks.
I've still got my 94 that I haven't put in. I just can't be arsed..
I need to get a new switch from Radio Shack and install it. I bought it last year and it's still just hanging out in a drawer. I'm afraid to put it in...
qsiguy
Car: 1994 Infiniti Q45 Turbo
I had my hands on a JWT TCU to evaluate. They had cut the "trans malfunction" warning output circuit and it had the EPROM changed. I would have liked to pull the code from the EPROM but it was a surface mount EPROM so I did not want to risk pulling it and damaging it. I tried it in my car but it didn't make a huge difference. I've been driving mine with the dropping resistor completely disconnected for a few months now. Every shift is very firm and solid, it even chirps the tires sometimes if I'm on it when it goes from 1st to 2nd. I'm sure it will wear it out faster but I love it and will just fix it when it goes. Might use that for my excuse to do the 5 speed swap...
As for the NICO ECU...sheesh! Just install that sucker, burn the bridges and don't look back! You'll love it. Normal driving you won't notice any difference, just when get on it and that's when you want it anyway. I don't understand why you are so afraid of it.
jettsetter4life22
ok qsiguy ill trust you so where can i get a nico ecu do you have one for sale. oh and also is that a turbo mounted back by your muffler?? how the hell did you do that. can you explain your turbo set up for me exactly how you did it and what kind of tuning you had to do to your engine to make that work??
Haitian_King
jettsetter4life22 wrote:ok qsiguy ill trust you so where can i get a nico ecu do you have one for sale. oh and also is that a turbo mounted back by your muffler?? how the hell did you do that. can you explain your turbo set up for me exactly how you did it and what kind of tuning you had to do to your engine to make that work??
Here's the thread with his write up of how he did it. zerothread/281662
Q451990
Haitian_King wrote:31036-64U20 I believe.
There was also one ending in 64U75 released as a countermeasure for t/c lockup shock - but I have never actually seen one. I suspect they weren't installed very often.
Heath
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Was the update on the above TCU used on the later TCU's?
qsiguy
It's all in the link that Haitian King provided. The engine is totally stock. Major mods and tuning to the ECU. Added methanol injection. It's not back "by the muffler" it's in place of it...
Get in touch with Wes (Elwesso) for an ECU. You can either send him your donor one or he may have some to swap with you. If you have trouble reaching him shoot me an email and I'll get the ball rolling.
