TCSand Slip lights come on
mikecon
Read the threads but my problem is a variation on the theme. The lights came on 95Q and drained the battery. Dealer replaced the battery and said the reason they came on was the battery was weak and didn't have enough juice to power these units and so they cut out.Now have new battery, Slip and TCS lights have come on again and drained the new battery. If the problem is relay problem as described in the thread, will this casue the battery to be run dead? If not, what is draining the battery when these lights come on and the car is left overnight?Mike
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Check the relays first, then the alternator.
Welcome to the board and thanks for searching before posting.
mikecon
Thanks. Going to the dealer tomorrow and i will ask them to do just that.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Get the parts from http://www.everythinginfiniti.com so you can sit comfortably in the future.
