TCS Slip light stays on
ahukill
Car: Q45
Brake pads worn light came on. It took two days to get pads etc. In that time, TCS light and Slip light come on and stay on. They are not right when the car starts. I am looking to sell this car and see if someone may want it for parts. It is really good shape. May be the age of vehicle. Any ideas? Does the TCS need to be replaced? Thanks!
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Hey there and Welcome to NICO!
If your brake light is on due to low fluid level it will set a code in the VDC system because the system will not operate correctly with a low fluid level. You may have to clear the codes after putting the new pads on and topping off the fluid( with new clean fluid from a freshly opened container).
What year Q are you trying to unload?
ahukill
Car: Q45
Q45 1994 Pearl White with BBS wheels
ahukill
Car: Q45
Thanks for the reply! Any fluid you recommend for it? Brand etc.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
DOT3 or 4. Castrol makes a very good one in Syntec. ATE Blue if you want to spend more money.
qship96
Car: 1996 Infiniti Q45
Then there is always Castrol SRF at $80 per liter for the truly brake crazy people!
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
ahukill wrote:Brake pads worn light came on. It took two days to get pads etc. In that time, TCS light and Slip light come on and stay on. They are not right when the car starts. I am looking to sell this car and see if someone may want it for parts. It is really good shape. May be the age of vehicle. Any ideas? Does the TCS need to be replaced? Thanks!
If both lights come on while driving, it could be something as easy as the blue relays under the battery. You'll need two of them. They're roughly $20 apiece.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Why not just truly diagnose the problem:
"Use this procedure to see what is causing your "SLIP" and "TCS OFF" lights to come on. The TCS control unit is located under the rear package shelf, in between the left rear speaker and the "box" that sits on the rear shelf. The aforementioned LED must be viewed from the trunk side, it is easiest to remove the divider."
By: Wes Stinson
