jbreckeen »
https://forums.nicoclub.com/jbreckeen-u166898.html
Fri Aug 27, 2010 11:24 am
Hello all.
I am diagnosing a problem in my girlfriend's car - a '97 Q45t. Yesterday the TCS off, Slip, and Check Engine lights came on, and the car has almost no power.
So, full disclosure - I am a lifelong German car man and have been wrenching on them for many years. But I have not done any work on Eastern cars - ever. I have used the search function of this fantastic site, and have come up with the ABS relay problem. I do like the fact that this part will have a small cost, but my question is would this problem affect the acceleration? Is this some sort of limp-home mode? Does this car have a limp-home mode?
To elaborate: the above lights come on once the engine is started without even moving. The car starts and idles perfectly, but as soon as you press the accel pedal, the engine just chokes all power - though it will not stall. If you are very soft on the accel pedal, it can accellerate and drive, but without almost any power. There are no abnormal noises coming from the car or abs actuator - except when you try and rev the engine, it just sounds like someone is choking it.
I have seen the FSM's on this site - thanks much - but I cannot work on it until this weekend, when I will pull the codes. So I am asking the collective wisdom here is this makes sense. In my German experience, it seems like the throttle-position sensor would be faulty, but I will check both.
Thanks in advance guys . . .
JBreckeen
St. Petersburg, FL
1997 Q45t
jbreckeen on Thu Sep 02, 2010 11:16 am, edited 1 time in total.
