qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Tue Oct 03, 2006 8:54 am
the turkey baste method IS NOT ideal,but way better than nothing if done annually.... brake fluid absorbs moisture,so replacing fluid in resivour with fresh dry fluid pulls the excess moisture out of remaining old wet fluid in system until moisture equalizes,why you do it 1x /day for a week.... also tcs system self tests every start and some of the fluid moves thru system helping to dilute old/new fluid again best/fastest way is to use the bleeder screws if you can access them.... bet no-one here has ever done it this way,and few even turkeybaste annually?
