TCS removal
morton27
Car: 1994 Infiniti Q45a, 1988 35th Anniversary Corvette, 2002 Lincoln Navigator, 2004 Dodge Ram 1500, 1988 Volvo 240
Hey guys I haven't posted much on here. My biggest claim to fame post was on the Infinti Q45 keys and where to get them cut in Phoenix, AZ for 35.00 versus 150.00. However, I am always on here reading the posts and commenting where I have some knowledge. So I want to remove the TCS system from my 1994 Infiniti Q45a. I don't need the headache. Anyone got any hints.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
morton27 wrote:So I want to remove the TCS system from my 1994 Infiniti Q45a. I don't need the headache. Anyone got any hints.
I think you need to look really hard at acquiring a Yugo. That car should be able to match your superior driving skills.
Q451990
Is your TCS causing an issue? I wonder if you could just unplug the relays or connector to the TCS actuator. You'd probably have to remove the light bulbs in the instrument cluster as well...
Or you could go further with it all and retrofit with all non-tcs parts. Throttle body, etc...
Heath
qship96
Car: 1996 Infiniti Q45
What kind of issues are you having with your tcs? In 249,000 miles, my tcs has had zero issues with just a annual turkeybaster suckout of the resivour and refill with fresh brake fluid......even the 2 relays are original.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Very little in performance would be gained by removing it if thats what your after. You sir a have a rare car and here you want to go and trash it all up by removing the good stuff. Sell the car and find a base Q45....
Modified by Paul Wall at 7:46 PM 3/31/2010
