TCS relay in '99 Q-where is it?
dodiho
Car: 1996 I30 1999 Q45
I have a '99 Q-built 4/99-Joe from Scottsdale sent me a new TCS relay...my problem: where is it located in the car? We think this will solve the TCS/Slip/ABS lights staying on ....help? and Thanks!
96Qowner
Car: 1996 Q45
Here's the relevant section of the manual:
Brake System Section of the 1999 Q45 FSM
Check the diagram on page BR-47.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Inside engine bay, passenger side, near firewall, on top of ABS control unit (with metal brake lines connected).
Also, make sure you post results in this thread as well as the other two where this is relevant so that future searchers will be able to find.
dodiho
BullitAndy...I think my relay is somewhere on the passenger side in the glovebox area....my Q was built later in the year and some changes were made...
96Qowner
Car: 1996 Q45
The 1999 FSM shows it in the engine compartment, passenger side, near the rear (pretty much where Andy put it). Throttle motor relay.
bullittandy
If you have the relay then match it up to the whatever looks like it.
I promise I'm not lying to you, your problem is very likely the relay and it is located where I said. I say this because this is the same conversation that we've had on several different posts.
Of course I could be lying to you....
dodiho
BullittAndy...I'm just going by what Joe in Scottsdale told me--he said my later made Q-per vin number-doesn't have relays in the ABS control pump area...said they were built in and not able to get to...then he said it was in some type of "box" on the passenger side glove box area...so I can't compare if I don't know where to look...I've tried buying a FSM from ebay-no luck....I KNOW you won't lie to me.....what kind of combined mileage are you guys getting from your Q's? Mine has gone down from about 23/24 to 20 on the highway in the last 3 months....thanks,Doug in Texas
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Should get 22 mpg at 75mph on tier 1 premium 93 octane.
http://www.nicoclub.com/fsm/Q45
The TSB are the killer as there is a ton of them that most ignore at their own peril.
dodiho
Brian...am totally blank: what is a TSM? Thanks!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Technical Service Bulletin
All are available at http://www.nissan-techinfo.com/infiniti/ for a one day subscription. Best to have high speed connection.
Navigation of the site is not intuitive.
