tcs probs?????? on z33
Nissan 350z / Nissan 370z general community discussion forum
peakboostrps13
Car: rps13
i have probs trying to do a stand still burn out do to the traction control, even when turned off.......... it dies out, is there any way to get rid of that if so can u plz tell me how
Derel
HAHA get a more HP
peakboostrps13
Car: rps13
its not the power its do to the abs kikin in while trying to burn out
joe603
Car: 2014 Durango R/T
you have to master heel-to-toe shifting....
Exar-Kun
Car: 2005 350Z
The ABS is activated on the rear when the TCS is on...so either you aren't turning it off, or you're power braking while doing the burnout...which is just ****ing stupid. That can damage your brakes, engine and drivetrain very easily. So if you're doing that....stop.
If you're doing neither and still not getting a burnout, I suspect you need more power to keep the tire broken loose.
-CHet
Derel
so what is the right way to do a burn out?
this was my old car before i got my Zburn outs where so easy
Exar-Kun
Car: 2005 350Z
Either get a progressive line lock, one that lets the bront broke off slowly, or just clutch dump it...
both will be stresfull on the car and it's drivetrain. Your best option is to just overpower the rear tires and leave it be. Forcing the rear tires to break loose first puts a lof ot mechanichal stress on the other components of the vehicle.
-Chet
peakboostrps13
Car: rps13
tanks but none of u guys were right i took care of it already
tanks neways well i wasnt the lack of power... i was just like i though
Derel
so what was it?
peakboostrps13
Car: rps13
it was abs problems
peakboostrps13
Car: rps13
not tcs just the fact of abs kiking in, like its supose too
C-Kwik
SCC magazine touched on this when the Z was introduced. When the brake pedal is pressed, the car will not be allowed to hit WOT. For a temporary burnout, the fix is to disconnect the brake lamp switch.
Derel
or just pull out your abs fuse......... lol
Return to “350z / 370z Discussion”
