The usual suspects are the blue relays under the battery. They can be replaced for around $40. That will get rid of the lights.aliciaford wrote:Ok, I searched this topic, however, there is much talk about how to disable the lights but what is causing these lights to come on? Mine just started, came on but then went away the next time I started it, now it is staying on pretty constant. Just the TCS and Slip lights are on. The car is still reading "OK" on the dash. I am just unclear on where to start and should I be driving it? Seems like nothing else has changed, no noises, ect.
The relay issue did indeed solve the issue. At least in my case it did.[email protected] wrote:Did you ever resolve your problem, as I am having the same one (TCS/SLIP LIGHTS ON).
Whoa? Are you talking about the 2002 Q45 you have in your description? Haven't heard of any F50's acting up that badly.Diesel6 wrote:for me those lights come on and the car does not go more than 25mph no matter how hard i press on the gas...the car just starts to shake when i try to go over 25mph...what might the problem be? this car is really starting to get on my nerves im thinking of getting rid of it...
I don't know enough about the F50 to really call it. Hopefully someone more knowledgeable than I can weigh in on the situation.Diesel6 wrote:yup the 02' Q
should i fix it or get rid of it?
Call Nationwide Infiniti in Timonium for an appointment....410.561.1000[email protected] wrote:I changed the two blue relays under the battery tray today, Monday. They were two "Relay-Inhibitors", part number 25230-89981. The TCS/SLIP lights are still on.
My diagnostic code was 13 led flashes. There is no malfunctioning part or unit affiliated with 13 led flashes on the diagnostic chart. How can I find out what this code is identifying as the problem?
Can anyone help?
could you let us know if you get an leads on this problem? i have the same problem. thanks.[email protected] wrote:I changed the two blue relays under the battery tray today, Monday. They were two "Relay-Inhibitors", part number 25230-89981. The TCS/SLIP lights are still on.
Can anyone help?
