tcs & slp light & noise
goren
Car: 95 Infiniti Q45
I have replaced the 2 relays under the battery & it has not helped. Either the tcs actuator or tcs reservoir or throttle actuator is humming when I start the car until the tcs & slp lights go on. I found by removing the TCS square fuse the tcs light comes & the the slip light comes on but there is no humming from the engine. What would suggest be my next move?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
if its up by the battery then its probably the TCS actuator.
goren
Yes it is by the battery. I am having trouble getting the part # for the tcs Actuator. I looked on the Infiniti part site & nothing showed up.Is this Tcs actuator part a part that I could buy used from someone on the forum? If yes, how would I know it is in working condition?
Does anyone have a TCs actuator for sale for a 95 Q45?
elwesso
2007 BMW M Coupe
Yeah you could get a used one.. Price depends.. I think 100-200 is a good price..
goren
I believe the TCS Actuator Part # 16120-67U-10
Can this also be called TCS Motor Assembly?
As you probably tell I have no experience buying auto parts online.
I called Joe & they quoted $406.85 new
Any sugestions.
Thanks for your time.
Erin
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
elwesso wrote:if its up by the battery then its probably the TCS actuator.
wes where is the pump in relation to actuator
elwesso
2007 BMW M Coupe
goren wrote:I believe the TCS Actuator Part # 16120-67U-10
Any sugestions.
Erin
The MOTOR and ACTUATOR are different... To answer James' question, the MOTOR is located in the passenger side fender well, the ACTUATOR is located right by the battery...
In my parts book im seeing 41810-60U00- ACTUATOR ASSY- TRACTION CONTROL...
goren
this is goren. I have a picture of the TCS system. The tcs pump is on the passenger side in front of the battery. It looks like it is where the left bumper starts.Hope this helps.
Erin Goren
