elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sun Oct 22, 2006 6:39 am
heres my theory:
The ABS system (TCS cars basically are just 4 channel ABS) is configured with the 3.54 gears... Since the computer is configured at this rate of spinning, it may throw everything off..... With the stock gears, it is allgood, but with the 4.08 it thinks the rear is spinning faster (which techncially it is, compared to thef front)... Since both rear sensors are spinning at the same rate, it compares it with the front, and then assumes that one or both of the sensors is messed up...
Since you cant replace the pinion gear on the speed sensors in the rear, you may be able to change the sensor ring to one made for a 3.54... From the factory, the Q has a 48 tooth sensor rotor front and rear. The 300ZX has 46 teeth.. if this is the case, its likely to think that the front of James' Q has a 48 tooth rotor up front and a 46 tooth in the rear...
First thing id do is measure the resistnace of the sensors as outlined in the FSM on page BR 86.
I see 2 ways to diagnose this....
1. Count the number of teeth on the front and rear sensors...
2. Compare the voltages of the front and rear sensors.... this would probably be the easiest way to start since you really dont have to take anything apart, you just have to stick needles on the harness and put your VOM up there. Problem is how do you compare all 4 voltages while your moving?? You have kids, right????
According to my theory, the voltages at the TCS control unit should be the same FR/FR; as well as RR/RL, but the average voltage between front and rear should be different....
im inclined to think that the secondary TPS problem is seperate... i dont want to worry about that now...
