mcrews »
https://forums.nicoclub.com/mcrews-u32466.html
Mon May 29, 2006 8:20 am
Marksport,
I used Radial Tire Store in Sacramento. The were the highest reccomended shop on TIRE Racks list. ( I ordered the SWIFT Springs from Jason at Burtman. They weighed almost 4 lbs apiece and the stock spring were just a 8lbs) They have done lots of lowering springs.I had ordered KOMHOs 255/45/18 from TIRE RACK and had them installed there about 1 month ago. amount lowered:The fenderlip measurements to the ground were:before 28 7/8 front 27 7/16 rearafter 28 1/4 front 26 3/4 rear (day after install)now that the warning lights are on, the front is still the same but the rear is now 26 7/16 and the rear wheels are leaning in slightly.
THe first day I had the spring on there were no warning lights and I could tell the difference in the ride. IMO, I could feel more of the bumps. Since I did'nt get much lower, I was still undesided about the change. Also I run 39lbs in the tires ( I am on the freeway alot and the higher pressure seems to work better.) so when the warning lights came on and the systems went off line, I decided to re-evaluate the springs next week.
So back to your ? on the install....ran into the owner at Jamba juice on Sat and he said to come back on wed. His top mech is back from vacation and he like to have him in on it.So when you did the install, did you have to unhook any sensors?
ThanksMark
Modified by mcrews at 11:44 AM 5/29/2006
